Philco 37-61 problems
Wonderwrench(Bill) Thanks for your idea, I adjusted the osc. for best performance and just moved the dial to align with the stations. It's not right but It's better than it was.
Thanks all who helped
Tom
There are currently 7117 online users. [Complete List]
» 4 Member(s) | 7113 Guest(s)
AvatarAvatarAvatarAvatar
