A trimmer adjustment tool.
(09-18-2016, 10:14 PM)Joe Rossi Wrote:
(09-14-2016, 01:32 PM)PhilcoPhan1936 Wrote:  I just ordered one. Hope to have it this week, though it might be a while before I actually put it to use.
Jeff, There are only two reasons to buy tools immediately; either you need it or you might need it sometime.   Icon_lol
Joe
I have at least 7 1930s Philcos left to restore at this point. So it definitely will get used when I get around to them! Icon_thumbup
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
....and it'll fit other radios too.
