Philco signal tracer model 7030
I have picked up a 7030 in very good exterior condition, makes a nice display piece. I am wondering if restored it would have better performance than a common Heath or Eico unit.
Thanks
Hank
I have one that I replaced the caps in and had to resolder the cable where it went into the probe. There is a tube in the probe.
I have not used it for troubleshooting yet but here is an instruction manual in case you don't have one.
http://www.myvintagetv.com/Apple%20PDF%2...Tester.pdf
Don't know if its better than Heath or Eico. Maybe someone can comment on that.
(10-01-2016, 08:39 PM)KCMike Wrote:  I have one that I replaced the caps in and had to resolder the cable where it went into the probe. There is a tube in the probe.
Thanks, I downloaded the manual, sounds interesting.  I think I will go throuth it, and try it out.  I did slide the the probe apart, some of the terminal clearances are very close and could use insulation.
Hank
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9357 online users. [Complete List]
» 2 Member(s) | 9355 Guest(s)
