Have a question about cap. substitution
     Hi,
     Need some help on a cap. substitution for a Philco 90 (one - 47 tube) model.
     I am rebuilding the bakelite blocks and part 38 on the schematic calls for two
     0.09 caps. What should I use for a substitution?
     I have 0.1 caps and 0.15 caps, which one would be the best to use?
     Thanks for all the help.
     Tom72
The 0.1uF caps will sub in there just fine.
Ditto.
     Thanks so much Bob and Morzh
     Tom72
Restoring Philco 96
There are currently 5298 online users. [Complete List]
» 4 Member(s) | 5294 Guest(s)
AvatarAvatarAvatarAvatar
