Atlas Radio
 Looks really good. Got yourself a nice  radio there. Enjoy Icon_thumbup
That radio is a real beauty now, congratulations!
Hi Paul,  The cabinet looks great cleaned-up, and I like the grille cloth pattern.  Do you think the cloth is original?  Sharp find!  Icon_thumbup   Joe
Joe
Not too many of these to compare cloth to, it is old enough but could be and old replacement. Maybe a mystery.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6203 online users. [Complete List]
» 1 Member(s) | 6202 Guest(s)
