Philco 16-121 and -122 sch error
An error: the top 42 tube of the push-pull stage in the sch has the screen grid disconnected from the plate.
They should be connected.
Dunno if that was noted here before, so report it just in case.
There are currently 3506 online users. [Complete List]
» 2 Member(s) | 3504 Guest(s)
