Alignment ? West WR12X5
Morning, I have a Westinghouse WR12X5   http://www.nostalgiaair.org/pagesbymodel...024342.pdf
My questions concern the first 2 items on the  alignment procedure. They are
IF grid - is that 12SK7 pin 4?
1st Det grid - is that pin 4 or 5?
Thanks Eric
Hi Eric, I put the schematic up again it won't link if its on a line with other words.
IF grid is pin 4 of the 12SK7
1st detector (mixer) grid is pin 8 of the 12SA7
Thanks for the info on posting links, No wonder it wouldn't come in on the 12SA7 will try it this afternoon.
Thanks!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
