Schematic request-Philco 7030 signal tracer
Beautiful piece of test equipment, has engine turned (swirled) front panel.
For $19 total, I couldn't leave it in local consignment shop.
Anyone have a schematic for this?
Out of room, still dragging 'em home
Hi
I knew I had some info on Philco Test Equipment around here somewhere (with many thanks to Chuck who sent it to me in PDF format). Finally found it this morning...unfortunately, it only covers prewar Philco test equipment, and so it does not include your (postwar) 7030. Sorry about that.
Already sent you a PM about the availability thru my website, M.H.
10 pages or so, including user guide and troubleshooting techniques with the 7030.
Icon_smile
Happy Holidays!
Chuck
