37-630 Intermittent issue - solved
(12-23-2016, 11:56 AM)morzh Wrote:  What worries me about the silicone that is sold in stores, it really reeks of vinegar and from what i read it is for a reason - it does either exude acetic acid when curing or something to that effect.
Acid could damage wires.
Maybe it's an empty scare but I do not like acid smell near copper wiring.
It isn't an empty scare.
DO NOT use silicone on electronics. Period. End of story.
I know someone who repairs marine transceivers and related equipment for a living. He once described to me the results of potting a box full of copper wiring with silicone. He received a repair call because whatever was connected to the box stopped working. He opened the box and found that the silicone ate the copper. That's right - very little copper left.
After he told me that, I have refused to use silicone on any electronic item since.
I hadn't heard that. My bad. Icon_redface  Thanks Ron.
Tim
I took Ron's advice and bought some clear epoxy at Lowe's this morning. I just put it on the SM and now have to wait for it to set.
TV: Yes, intermittent problems can be a pain, which is probably why I waited 6 months to get the ambition to chase this one down.
Thanks for the suggestion KC. That looks like it might have worked fine as well.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6920 online users. [Complete List]
» 3 Member(s) | 6917 Guest(s)
