Hallicrafters S-38d
if anyone needs any help gettng a Hallicrafters S-38d runnng, give me a buzz 304 772 3411
I wont ever see this thread again because i am just posting to say i have restored one and got it running very well.
I can..........
give you voltage readings i am getting at test points to compare your radio
send pics of how mine is restored ect.
here is your capacitor list to get all the caps redone including the quad filter cap.
4 section filter cap c14A,B,C,D
20uf       25vdc                    qty need-1 + 1 spare
40uf       150vdc                  qty need-1 + 1 spare
60uf       150vdc                  qty need-1 + 1 spare
This is the list of random paper caps throughout the remaining schematic
.01uf      200vdc                  qty need-1 + 1 spare
.01uf      600vdc                  qty need-1 + 1 spare
.02uf      600vdc                  qty need-1
.02uf      600vdc                  qty need-1 + 1 spare
.05uf      600vdc                  qty need-1 + 1 spare
.05uf      200vdc                  qty need-1 + 1 spare
Scott
Your post will always be here unless you delete
Sam
10-4, thanks!
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4763 online users. [Complete List]
» 2 Member(s) | 4761 Guest(s)
