38-116/38-690 speaker
Was wondering if anyone knows are the main 15" speakers of the 37/38-116 and the 37/38-690 the same? In the parts catalogs they list them as different part numbers but they appear to be of the same design...
Check the resistance of the field coils. That would tell you.
Good luck with the project and all of us here are expecting a full report when you're finished.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4475 online users. [Complete List]
» 3 Member(s) | 4472 Guest(s)
