Philco 70 Brads
Hi guy's I am starting to restore a model 70, the escutcheon is in great condition but it is missing the brads that hold it to the radio. Where can I find some to match the original ones.
Thanks
I probably will have other questions about this radio in the future.
Jim
Jim
Spring Lake MI
Hopefully someone will have a more specific answer but I would go to a local hardware, one of those places that has stuff everywhere and a guy that's about 90 years old still working there that knows where everything is.... they don't have many of those anymore but you might find something. Icon_smile
Look here    https://www.mcmaster.com/#nails/=15338y5     Try stock number 97936 A 109
M R Radios   C M Tubes
Found some little brass nail's at ACE, just had to cut them to length.
Jim
Spring Lake MI
Icon_thumbup Icon_thumbup
Eico 232 VTVM Schematic
There are currently 6905 online users. [Complete List]
» 1 Member(s) | 6904 Guest(s)
