Philco 96 help please
For voltage measure you can use this    http://www.nostalgiaair.org/pagesbymodel...013901.pdf
It will get you in the balllpark. (model 95 diagram)
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 3528 online users. [Complete List]
» 1 Member(s) | 3527 Guest(s)
