Hello I have got a Philco 48-482 that plays with very low volume, is that a tube problem or something else? Mike Icon_biggrin
has any chassis work been done?
recap done?
if not try changing coupling cap to output tube and retest.
phil
There are currently 11378 online users. [Complete List]
» 2 Member(s) | 11376 Guest(s)
