Philco 40-130 and 40-140 are factory manuals the same
Hello everyone,
my big question for the day far as a Philco 40-130 and 40-140 are the factory service manuals from Philco the same ones basicaly with a few extra papers or do I need both of them .
Sincerely Rich
