alignment instructions,116x
anyone have this info and can post/email it for me?
thanks,phil
Phil, there is some information in the Rider's schematic:
http://www.nostalgiaair.org/Resources/235/M0013235.htm
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
There are currently 10384 online users. [Complete List]
» 3 Member(s) | 10381 Guest(s)
