GE radio
I have a GE X577 radio and can't find anything about it. Does somebody out there have scehmatic about this radio or know where I can get it. This radio has a wrong tube in it when I got it. It says suppose to have 5Y3GT, and it has 5U4GB? What will that do to the radio if anything? I have not turned it on yet with my varic concered my burn something up! Icon_smile Thanks Mike
The 5u4 draws more current on the heater, 3 amps vs 2 for the 5Y3. Don't do it. Shut it down and get the correct tube.
Mike,
Can you post the complete tube line up?
Can't find anything with that model number.
Carl
Northern Panhandle, WV
Eico 232 VTVM Schematic
There are currently 4922 online users. [Complete List]
» 2 Member(s) | 4920 Guest(s)
