Kolster K-20 Resistor
Hello, all.
I am working on a Kolster K-20 and need to replace two out of spec resistors on the ceramic multi-tab resistor labeled z1 - z6. Two questions: Will 10 watt resistors be over kill and, assuming I replaced all of them, is it rebuilt the same way as a candohm resistor?
The schematic is here: www.nostalgiaair.org/pagesbymodel/092/M0040092.pdf
Thanks.
Dave
There are currently 8837 online users. [Complete List]
» 2 Member(s) | 8835 Guest(s)
