Philco 41-315 Output Transformer Replacement
One side of the primary of the output transformer is open. Can someone suggest a suitable replacement for 42 push-pull output tubes?
Thank you,
nv3g
Oscar
Hi Oscar,
https://www.tubesandmore.com/products/tr...output-8-w
The speaker table error?
Philco 70 antenna lead
There are currently 1831 online users. [Complete List]
» 2 Member(s) | 1829 Guest(s)
