Power Transformer info
Not sure if this is the correct forum for this so if not please move it. Anyway, I picked up a Philco chassis at a estate sale today that was on its way to the trash bin when i showed up. There are no identifying marks on it as to what the chassis is but the power transformer is marked 5117J. Is there a listing somewhere that gives the part numbers for these to cross to models used in?
Can you post a pic of the chassis?? This will give us some sort of time frame to determine when it was made.
Both versions of Model 70 used that power transformer according to Philco's 1941 parts catalog.
Thank you Ron. Looking at the Riders the layout matches perfectly.
The speaker table error?
Philco 70 antenna lead
