Model 89 front finish
Hey, guys.  Wonder if someone could tell me if the model 89 has a faux finish on the front.  Something that doesn't look like veneer seems to be flaking off the cabinet I have here.
Can you show us a picture or two?
Wish I could, but haven't quite learned that skill yet.
There is a list of cabinets with photofinish in the Tech Section. The 89 cabinets are not on it.
Thanks for posting that Bob. So it looks like photo finish wasn't used prior to 1934? Ed
Don't think they were used till abt 1937.
