Need to identify parts 37-675.....
These parts are from a 37-675, used on other models too.   What are these parts called?
Have a look at the Automatic Tuning Service Bulletin (273):
http://philcoradio.com/phorum/showthread.php?tid=5938
I'd go by the names there.
excellent. thanks.
