My Phirst Philco
#61
Radiodaze has a few Shadow meter masks.
http://www.radiodaze.com/philco-60b-shad...m-ds-a681/
Have you cleaned the mask and dial? Dial should NOT be cleaned w/water but with mineral spirits. Water will remove print. If it still isn't bright enough you could use a led lamp.
The mask looks like something that might shatter if I wasn't careful. The link above shows a shadowmeter mask. Is that the same thing as for the dial pointer?
#64
Probably would just clean it w/oms too.
oms??
#66
Odorless mineral spirits
#67
Is that a painting type product or something else?
#68
Yes it is. Usually in paint dept. Like this.
https://www.lowes.com/pd/Jasco-32-fl-oz-...gINXvD_BwE
91H Code 126 Restore
