Indentification help needed, 1941 ish, 5 tubes
Hi new to Philco Phorum (nice btw)!
So picked 2 units for home display and decided on one to be first to get restored, need a bit of love but overall not too bad, I havent connected it yet to see if it works, according to the pictures provided, is it safe to do? I have looked at all pictures in the gallery and could not find the same design-model, anyone can help?
Robert
The reason you can't find it in the Gallery is because your unit is a Canadian model. Our Gallery only covers the US made models.
But, your model does look similar to a model I've seen before. Canadian models often mirrored US models, just with different model numbers.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Also, I wouldn't recommend plugging it in until it has been inspected to see when it was serviced last. If it hasn't been serviced recently, it should be before playing it.
Blessings,
Jeff W.
Jonesboro, Arkansas
Ron does have some info on Canadian models here:
http://philcoradio.com/phorum/showthread.php?tid=15021
Yours likes like 49T from 1942.
Thats great thanks! yes, it is a 49T 1942. http://philcoradio.com/images/phorum/49t.jpg
Welcome to the Phorum!
Icon_wave
Hello Robert,
What nice set .
sincerely Rich
There are currently 10458 online users. [Complete List]
» 2 Member(s) | 10456 Guest(s)
