Star-lite FM-530
Hello,
So I have this Star-lite that's been sitting around that I picked up at a antique place awhile back, I cant seem to find any info online about it. Is anyone familiar with them? There is a very small schematic printed on the bottom but i was hoping to find one online I can read. Any help is appreciated. Thanks in advance.
It's Sam's photofact #710-11 (1964). You can buy it from Sam's or ask around and someone might be able to scan it for you.
Thanks again Terry!
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1528 online users. [Complete List]
» 2 Member(s) | 1526 Guest(s)
