Emerson EC-301
Ok started on this  Thought it would be straight forward  BUT...
[Image: https://farm5.staticflickr.com/4916/4702...e293_b.jpg]
Here is underside.. Looks like all caps were replaced at some time..
[Image: https://farm8.staticflickr.com/7823/4629...814d_b.jpg]
Chassis parts do not seem to follow schematic..
More to follow.. Have to copy schematic to download..
Skip
Ok, Here is what I have.. seems power supply section has 2 additional resistors added..
1st picture is schematic I have..
[Image: https://farm8.staticflickr.com/7913/4702...0569_b.jpg]
Next picture is what is really there..
[Image: https://farm8.staticflickr.com/7807/4702...c1e6_b.jpg]
These look like factory installed.. But cannot be sure
Other problem is F/C I think speaker and F/C were changed..
Thoughts??
Skip
The first resistor is a surge resistor, some sets have them in series with the rectifier plate, and some do not, but most likely it is original. The 200 K resistor should be paralleled with a .2 uf cap, it's there to couple the B- to the chassis for shielding purposes, I don't know how critical it is as, again, some sets have them, others do not, either way the big paper cap is needed or the set will motorboat like crazy.
Seems the more I look into this .. They or who ever Replaced most of the caps with different values.. Found some .05 replaced with .10 found 2 .0002 replaced with .0005 It keeps getting better and better..
Skip
OK Ps the filter caps were 70UF and 20UF..
Maybe due to the F/C being 1092 Ohms..
Who Knows..
Skip
Ok I replaced the Electrolytic with the same value as was in it.
Then I powered it up.. I do not normally do power up until I replace all caps and out of tolerance resistors But since this seems to have so many different values in it that's not on schematic.. I figured why NOT..
It lives!! Surprisingly it works pretty good.. But now I an replace with the values that are in it or as close as I can get.
Skip
Some of those little Emersons play pretty well, some not so much. They may have had the small but "pretty good" thing sown pat.
Well, I found a wire not connected from the loop antenna it was supposed to go to ground. When connected it played much better.. But now on to the Recap..
Skip
Recapped and aligned radio.. Works great now
[Image: https://farm8.staticflickr.com/7927/4707...8d6c_b.jpg]
Cleaned up with a little Go-Jo and it looks pretty good..
Skip
Pretty cool dial too, nice job!
Thanks.. I have to work on case a little more.. But radio plays great..
Skip
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1512 online users. [Complete List]
» 3 Member(s) | 1509 Guest(s)
