Philco part numbers and values?
Exclamation
Is there a place I can go on the
Phorum to find the values of a Philco
33-5240-1 dual potentiometer?
Oscar
nv3g
And what set is it in??
Depending on the era of the set you might check the relevant parts catalog in the Philco Library:
https://philcoradio.com/library/index.php/parts/
There's also a searchable parts reference in the Philco Library - but it is currently limited to 1939 and earlier parts info and doesn't contain the part you listed.
https://philcoradio.com/library/index.ph...-controls/
Philco 38-690
Old Phorum thread to the rescue!
https://philcoradio.com/phorum/showthread.php?tid=13625
91H Code 126 Restore
There are currently 3303 online users. [Complete List]
» 1 Member(s) | 3302 Guest(s)
