B+ voltage discrepancies between rect tubes
Have two NOS tubes one is a US NAVY 5Y3 and the other is a ken rad 5Y3. The radio works fine with either but is this a common issue for these types of tubes? Let me know what you fellas think.
US NAVY
Audio B+ 280
Rect B+ over 300 my meter only goes to 300
Rf, if, det, B+ 201
Ken rad
Audio B+ 249
Rect B+ 302
Rf, if, det, B+ 179
Recently I’ve tested and swapped tubes in a few radios to get the best performance, or at least the theory that my radio is working better. I’ve measured AVC and Power Supply voltages too.
I’ve seen certain brands like National Union NIB and the like test not as good as some major brands. I think the way tubes were mass produced, they had minimum specs to meet, and if they did, out they went for sale. Military tubes are supposed to be built to better standards, so it’s possible that they can test better.
The bottom line, unless it’s a high end amplifier that needs matched pairs, most tubes are fine. Most radios will never notice the difference, even with a weak tube. You’d be surprised how good a radio with weak 45’s can still sound.
Tony
What does schematic give for B+ reading?
US Navy mfg'd by?
May be a 5Y3/6087?
Tom
says C.H.S. on the navy tube.
CHS should be Chatham, basically Tung-Sol's division that produced mil spec and other speciality tubes.
Without knowing voltage specs, no clue if one is high or other is low. Not uncommon for B+ to vary 5-10v on different new tubes but 30v is excessive.
Tom
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2084 online users. [Complete List]
» 2 Member(s) | 2082 Guest(s)
