41-280 Station Glass Photo?
Hello,
I recently ran across a 41-280 cabinet on Facebook Marketplace and I need a bit a help.  My cabinet didn't have any of the electronics in it so I'm turning it into a Raspberry Pi driven jukebox.
Would somebody mind sharing a good head-on photo of the lighted station glass?  I'd like it to use it as a screensaver.
Here are a couple photos of my project.
[Image: https://i.imgur.com/hO8FfxT.jpg]
[Image: https://i.imgur.com/bMYCOAJ.jpg]
There are currently 9906 online users. [Complete List]
» 1 Member(s) | 9905 Guest(s)
