Philco 53-960 Dial Glass Help?
If no one has a 53-960 dial glass (I'd even take a broken one I can glue at this point), could someone possible take a High Resolution, clear and clean photo of the glass?  I could create a decal that will place-hold until a 53-960 parter comes available.
Thanks![Image: https://philcoradio.com/gallery2/1953a/#Model_53-960]
I could try.
All I could ask, kind sir.
You may want to check with this outfit. They make reproduction dials for these radios. I don't know if they have your model in stock, but with a clear photo of an original, they can make one. check with them.
http://www.radiodaze.com/
Thanks!
