Motorola 3MFT
I recently began restoring a 1955 Motorola 3MFT truck radio and I’m having trouble finding diagrams on it (parts, operation, etc). Does anyone have info or know where to get information for this radio? There’s a bunch of numbers all over it but, I can’t find out what anything means. Still working on the Philco, just taking a break
Its actually a 5MF, I found some info on it but not much
Some info from Beitmans.
Can anyone please tell me how to remove these push button arms from the radio? They move in and out smoothly then stop like they should so, there must be a way to completely remove them but, I can’t figure it out. I want to clean them up and get at a little bit of rust that I can’t get to easily with them in.
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2604 online users. [Complete List]
» 3 Member(s) | 2601 Guest(s)
