Truetone model D1042 question
Hello guy's,
Have a question concerning a 1940 Truetone D1042.
Re-capping, and am having a hard time with the schematics.
Very unclear to me and no parts list to boot.
Question is, there is a double filter cap attached to the inside of the chassis.
Markings on the cap state red, 4mfd x 250 dcwv and yellow 20 mfd x 12 dcwv.
Ground wire is on the end with the red lead and goes to chassis gnd.
Looks like the yellow goes to 6Sq7 tube pin 3.
Red wire was broken off of where ever it belongs.
I am guessing it goes to on of the 6SK7 tubes adjacent to the filter cap.
But I am at a loss and do not want to just guess.
Any chance one of you expert schematic readers could tell me where to attach the red 4 mfd lead?
Tube and pin number would really help.
Also, can I use a 20 mfd x 160v cap in place of the original 12v cap?
Thanks ahead for any help.
murf
Hey Murf, if this is the correct schematic for you radio.
http://www.nostalgiaair.org/pagesbymodel...023653.pdf
It looks like C3B red wire from cap goes to a 2000 ohm resistor R36 that is connected btwn. pin 4 of the 6SA7 and pin 6 of 6SK7 RF tube.
Yes you can go up in voltage on the cap.
Ok, great.
I see that now looking at the schematic.
Just wanted to make sure I am reading it correctly.
Thanks Mike,
Murf
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
