40-180 Preselector switch bank coils.
I have a Philco 40-180 chassis that has an open coil for the #7 preselector switch. On the schematic it is coil G.  Should I cut my losses
and leave it with just the 6 operational buttons,or should I try to find a replacement coil somewhere and replace it? Being that it is the
last coil in the assembly,it should be easy to change.Also, does anyone have a coil or even a whole coil assembly that they could part
with?
Thanks, Fred Martin
Fred,
I can send you the complete coil assembly out of a 41-295..same 32-3042 & 32-3041 coils.
Just PM me you mailing address. John
There are currently 4413 online users. [Complete List]
» 4 Member(s) | 4409 Guest(s)
AvatarAvatarAvatarAvatar
