Polishing chassis components questions
Threads: 42
City: Jeffersonville
State, Province, Country: PA
Morning all -
I'm finishing up a 38-9 and have completed re-stuffing the caps and bakelite blocks. (Steve Davis, the tools I got from you worked great, thank you)
While I've polished plenty of automotive components over the years, is there a preferred method for polishing radio chassis components? I have the tools for grinding and polishing but is there a specific polisher everyone is using to make these components look like new?
Thanks all,
Threads: 268
So what parts are you thinking of polishing??
Threads: 112
City: Medford OR (OR what?)
The zinc plated stuff won't stay polished for long.
Be careful, some manufactures used cadmium plating (yellow fuzzy oxidation) which can be very bad for you if inhaled.
Threads: 55
City: Lexington, KY
Member Geoff has some pretty detailed threads where he is very meticulous at cleaning and polishing the chassis parts. While I know he has done Philco before but all I could find was his thread on a Zenith:
https://www.philcoradio.com/phorum/showt...p?tid=4917
He likes to use Simichrome polish but I think any good metal polish would work pretty well.
[Image: https://antiqueradios.com/gallery/main.p...alNumber=2]
The above is a picture from his thread.
Threads: 15
City: Weymouth Ma
Very nice looking. While I will say that I like to fix radios I have to say I don't really restore them to like new condition. I would never polish an escutcheon unless it was rusted maybe but I am at odds at polishing the old copper electrolytics.
Henry
Threads: 416
City: Boston
I am lazy
Unless some set was very unique and a great find I just try to avoid those that may have heavy rust or are really grundgy. Unless it was a real special one. Much like the eternal cabinet disussions the call to make it look new or to have that patina or authentic aged look is really one for the owner. That chassis looks beautiful, despite what your taste is I admire the skill and workmanship.
Threads: 55
City: Lexington, KY
I don't like to over polish an escutcheon but I did polish the Mershon caps in my 70 and 90.
Threads: 42
All great points. I've only made repairs and haven't polished radio components to like-new condition either and was wanting to give it a shot with all this extra time at home. After Terry asked which components it appears the options are limited on this set. Been reading up on past 16b restorations as I prepare to start mine and the polished Mershon caps caught my eye.
I'm trying to avoid getting too lazy myself Paul! I also collect antique Smith & Wesson's and in that world the aged patina is desirable, much like furniture.
As always, thanks for your input guys.
Threads: 416
City: Boston
I am developing patina as I type  . Paul
Threads: 42
Your value is increasing by the minute!
Threads: 15
City: Weymouth Ma
I am getting too much patina. Too much grey and starting to shine some on top!.
Oh well,
Henry
Threads: 268
I've heard that a good soak in vinegar takes off a good amount of tarnish and such...
To get back on subject just to clean the aluminum cans up a bit I've used a soft Scotch Brite pad (white one) and some WD-40. It's good for cleaning up the corrosion on the tops. On some of the sets the IF shields are spot welded together so they come off as one unit.
(This post was last modified: 05-07-2020, 05:31 PM by Radioroslyn.)
Threads: 42
Thank you for the tips Terry. Very much appreciated.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4566 online users. [Complete List] » 1 Member(s) | 4565 Guest(s)
