Put new speaker to the philco model 90 and it does nothing
Hello friends:
I bought a philco model 20 radio about 8 years ago, but the wooden grille needs to be restored, but hey, the speaker was missing. stations with the speaker that I bought that can be to see if I have time and I will send you photos I would like if someone has the technical sheet.
A greeting.
https://philcoradio.com/library/download...l.%201.pdf
This is the schematic.
As for the speaker, I am not sure what you meant. Is it missing or do you have a new one?
This Google translation is very, very confused.
Hi,
https://philcoradio.com/library/index.ph.../speakers/
Go to page 4 and what you are looking for is called a "K" speaker.
This lists the specification of the original speaker. A replacement
output transformer would be 6000 ohms center tapped and
secondary to match the voice coil.
Hope this answers your question.
Ron Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text t...morzh — 02:00 PM
Eico 232 VTVM Schematic
There are currently 6566 online users. [Complete List]
» 3 Member(s) | 6563 Guest(s)
