Solution for Broken 1940's Pushbutton On/Off Switch
I posted this on ARF but it should be here also. My customer had a broken switch on his 1941 and did not want a new one on the rear panel.
Here is my solution which makes the set appear original. I hope this doesn't break a rule.
https://www.antiqueradios.com/forums/vie...6&t=385528
Philco 49-1040
