Philco 41-608 electrolytics
Threads: 1
City: Fort Pierce
Restoring a Philco 41-608. The filter cap installed in philco part #30-2488S. Markings are Red 16-400 / Green 8- 400, Black Com, Neg Blue 12-400 / Yellow Neg. Thats 5 leads coming out of the can. The schematic shows the 12 mfd (C21B) negative going to the 780 ohn, 268 ohm junction of R77. The negative of the 16 mfd (C21A) going to the 28 ohm and 26 ohm junction of R77. The 8 mfd (C21) negative goes to ground.By my count that is six (6) leads. The wiring in the radio hace the Black to ground, the Blue ((C21B) to the field and the 7Y4, the Green (C21) to the junction of R20 R26 and R36, the Yellow (C21A) to the junction of R77 780 ohm and 268 ohm. Is my schematic wrong?
(This post was last modified: 05-20-2019, 09:03 PM by islesailor.)
Threads: 268
Using the diagram fo the library it looks correct. There are three separate caps but there is no "common" because none of the minuses are connected together. This is why there are six wires.
Threads: 1
City: Fort Pierce
The problem is the current can in the radio does NOT have six wires, only 5. I have cleaned out the can and rebuilding the electrolytic package and wondered if I shouold wire it according to the schematic or the wat it is dcurrently wired in the radio.
Threads: 268
I would follow the diagram. Do go w/450v caps. A couple of 22 and a 10mfd will be fine.
Threads: 271
City: Wilsonville
State, Province, Country: OR
The 8uF portion of the #21 can has its negative lead to ground so they probably internally connected that electrolytic to the can and used the can mounting to the chassis to make the ground connection. Thus you only need 5 wires for the remaining connections.
Threads: 0
City: Cleveland
State, Province, Country: Ohio, USA
On any other forum this would be considered a zombie thread, but since we're dealing with 80-year-old radios, no thread ever dies
I ran into the same issue as islesailor, so I carefully dissected the 30-2488S cap to determine what was really inside. The description on the can is correct: there are three sections, but two of them (Red - 16uF and Green - 8uF) share a common negative lead (Black), and the third section (Blue - 12uF, Yellow - Neg.) is isolated, hence the 5 wires. There's no internal connection to the can.
Now for the schematic. I believe the wiring for the cap is incorrect as shown, for three reasons:
1. Since the black negative lead is common to the 16uF and 8uF, it can't possibly go to the two separate points shown.
2. The schematic doesn't match the way the 41-608 was wired at the factory.
3. The cap wiring doesn't match the power supply design of other, very similar sets, e.g., the 41-280, 41-250 and 41-610.
Unfortunately, the schematic error seems to be an old-timey literal copy/paste that got propagated through several models.
The factory wiring of the cap in the 41-608 does match the 41-280 design, and it makes sense. The negative side (black lead) of the 16uF and 8uF actually goes to chassis ground, which is typical of the design of many radios. I'd highly recommend wiring this way when re-capping, because wiring according to the 41-608 schematic could introduce noise on the output. I'll try to confirm this when I'm at that point in the restoration process.
Cheers!
-Brian
Threads: 268
There is a reason why 21,21A, and 21B are wired as per the schematic.
21A and B filter the both the B- and B+ outputs of the power supply. If those are connected to the chassis and the bias resistor it will short out any negative voltages used to grid bias the 1st audio stage and the output stage. Means excessive plate current and distortion.If you just connect them to the chassis w/o connecting them to the bias resistor then they won't filter out the 60cy hum in the - side of the power supply. Means hum. 21 is used for decoupling any audio signals that maybe modulating the B+. It's only connected across the + side of the hv.
Threads: 0
City: Cleveland
Good afternoon, Terry.
tl:dr: The only change I'm recommending is as marked in the image here: 41-608 correction. This makes the schematic match the as-built reality of a factory production 41-608 unit.
The long version:
If you re-read the original post, I didn't suggest that -all- the negative connections for 21, 21A and 21B should go to the chassis. 21B is correct as shown but, exactly for the reasons you cited, the negative connection for 21/21A should (and does, as built by Philco) go to another point -- in this case, the chassis.
I'll try to restate and clarify:
1) 21, 21A and 21B are all potted in the same can, marked 30-2488S on the side, also marked 30-2488 on top of the can. Upon dissection, 21B is completely isolated, having its own negative lead (the yellow wire). 21 and 21A have a single, -common- negative lead (the black wire) coming out of the can. This agrees with the printing on the side of the can, and this is why there are only 5 wires exiting the can, not 6. There is no internal electrical connection between the can and any of the caps.
2) As manufactured, it's impossible for 21 and 21A to be wired according to the schematic. They have a single, common negative connection (the black wire as stated in #1 above), but they are shown connected to two, electrically separate points (chassis for 21, jct. of the 26 ohm/28 ohm on 77 for 21A) on the schematic. In reality, factory wiring has their common negative connection (black wire) to the chassis, which is exactly how the 41-250, for example, is wired.
3) Opinion: Even if it was possible with the original part, I don't think there's a good reason to bias the negative side of 21A below chassis ground, and it may even be detrimental to the operation.
See what I'm saying?
Cheers!
-Brian
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
There are currently 4871 online users. [Complete List] » 1 Member(s) | 4870 Guest(s)
