Philco E976
All Has anyone worked on this radio? Stupid question How do you get the knobs off??
I tried pulling bu will not budge.
Skip
Try wrapping a strong cloth around the back of the knob then pull outward.
If it does not work (I do not remember Philco using set screws there - make sure there are none) use PB Blaster or WD40.
Same thing you did on Grundig.
Philco 49-1040
Philco 49-1040
There are currently 4080 online users. [Complete List]
» 2 Member(s) | 4078 Guest(s)
