38-116 dial replacement
i did a search on the site and did not see anything so can someone tell me how to replace the dial on a 38-116 are there any phots out there
benny
The 37-116 is pretty much the same. There was two version or what Philco calls codes. The 37-116X code 121 was a manual tuning set made during the 1st half of the model year. It was a poor seller but command a good dollar nowdays. It's very different from your setup.The 37-116 code 122 is overall very much like the 38-116X, same tuning scheme.
In saying all this have a look at the 37-116 dial disasembely. Oh the 37-675X does too.
What exactly are you looking for? How the dial is assembled, or where to get a replacement for the dial? I have pics of the disassembly of 2 37-116's and 1 38-116. I think I can come up with enough pics to show how the assembly is put together.
Benny, give this link a look see. It’s from the Philco Repair Bench website and has a detailed view and instructions on the 37-116 mechanism which should be close to what you’re looking for!
https://www.philcorepairbench.com/wp-con...ervice.pdf
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
well i just ordered a new dial from radio daze and what i am looking for are instruction's or photos of how the dial comes apart so i can replace my dial. ron that looks like a good start thank you
