Philco 271code121
Hello everyone
I am looking for technical information Philco 271code121
made in canada
Got some pics of it?
By chance a 71 with phonograph?
Thank you
Photos chasis
Hi Bartolome,
From your pictures, it appears to be a 71 chassis (371 in Canada) but it has some kind of factory modification. Does your dial show a shortwave or police band on it? Where are you located? I don't find any specific documentation in my manuals...but there is mention of different parts/transformer for 230 volt sets, so I'm assuming for export overseas.
