philco 211 speaker
I have a 211 speaker and the volume seems low. How do you remove the front ring? I tried tapping with a piece of wood but it won't budge.
That's one of those antique things. I think someone said the front ring spins-twists slightly to release it.
Are you sure it is the speaker?
Hi Lou! Welcome aboard! Icon_biggrin
As Chris (0Z4) mentioned, you will need to firmly grasp the outer ring surrounding the grille cloth and, while pushing down, twist it counter-clockwise. That should take care of it.
Be advised #1: It is just as hard to put back on as it is to take off. Icon_eek
Be advised #2: The driver is made of pot metal, and many of these speakers have been rendered useless as a result of swollen pot metal. You may end up having to replace the original driver with a 4 or 8 ohm speaker and suitable matching transformer.
Welcome to the Phorum!
Icon_wave
Thanks Ron, I looked in there with a flash light and I can the the cracked pot metal. I'll have to get my weight lifter son to try and twist that ring, must be getting old.
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 1901 online users. [Complete List]
» 1 Member(s) | 1900 Guest(s)
