37-9 grillecloth question
I have been looking around, and I have seen mentioned somewhere that the ribbed grillecloth on my 37-9 is not as original. I read somewhere that it should be a chevron pattern.
I was wondering, there are 2 different chevron patterns that are on radio grillecloth website. #3 is a darker color and 18 inches wide (should fit)
#41 is a wider pattern (22 inches) and is much lighter in color.
what is the proper pattern for the 37-9?
Thanks and regards,
Kurt
You need to use pattern 3. Pattern 41 is for 1938 Philco sets.
Thanks Ron, I was actually hoping that was the one, I think that it looks better.
73
Kurt
There are currently 9430 online users. [Complete List]
» 1 Member(s) | 9429 Guest(s)
