model 48 - 1253
I just got this set plays great . But going to go ahead & recap . was wondering wher could i get phono needle at .
Does this set play 33 1/3 records. For a 62 year old set looks new.
Thanks Denver Icon_biggrin
Hi
If your 48-1253 has its original phonograph, then no, it will not play 33-1/3 rpm records - only 78 rpm records.
Needles and styli may be found at West-Tech Services and Garage'A Records. Links on my site's Resources page:
http://www.philcoradio.com/resource.htm
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4384 online users. [Complete List]
» 1 Member(s) | 4383 Guest(s)
