1935 Atwater Kent Model 456 on Youtube
Hello Phorum
I have a new series on an Atwater Kent Model 456.
Part 1 link below to anyone interested
https://youtu.be/n3ar_HLBw4c
That's a project! I'm looking forward to more installments. I'm also enjoy those old 8mm films you've been sharing.
Thanks for doing the videos Buzz!
Thanks Buzz !
Hello All:
Part 2 of this series is now uploaded
link below to anyone interested.
https://youtu.be/bhKyRA-gq4U
Part 3 is now uploaded. Link below to anyone interested
https://www.youtube.com/watch?v=wIYJmCer...l=Buzz1151
Hi Buzz ! That was very interesting, but I'd say you still have a way to go. That set should be WAY more sensitive than that, even with a fairly short antenna. Of course, I didn't see you do any alignment on the video, so, that will probably help. I'll look forward to Part 4.
It's coming along nicely Buzz, that new dial looks great. Enjoy that premium whiskey, Dickel is so generous Icon_e_wink
Part 4 and FINAL episode is now uploaded.
https://youtu.be/dE7ceYBjdeE
