Philco PT10 - Need pictures
I have a PT10 Philco that has been mauled by someone.  Wires have been cut or disconnected and some of the caps have been removed.  All the coils, transformers, field coil, and output transformer all  check out ok so I think this radio could be restored.  I have the schematic but it would really help if I could get a few detailed pictures of the underside and top of the chassis.
Thanks, Bob
Bob, drop down to the bottom to the Philco Radio Library. 1941 service manual and schematic available there. Take care and BE HEALTHY! Gary
Like this: https://philcoradio.com/library/download...20Book.pdf
If the wires aren't cut short you maybe able to tell where they go. Since it's a '41 set you mize well rewire it. A lot of it going to be intuitive just from placement. Keep your leads short as possible and neat. Somewhere around there is a Philco color code list which could be helpful to sort pri 2ndy on the IFTs.
Rf and osc coils the ohm meter is going to be your friend to determine the pri/2ndy. Then trial and error.
I had a 40-2** console that was given to me that was in a similar condition. I really went back together pretty easily. Kinda backwards from what we do most of the time...
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
There are currently 3600 online users. [Complete List]
» 3 Member(s) | 3597 Guest(s)
