Philco 630 - Static Noise Crackling.
The 630 I rehabbed was playing pretty good. Now it plays well on strong stations but a lot of static on weaker stations and while tuning between them, I probed around with a plastic alignment tool and notice that when I put some pressure on the 2nd IF transformer the Volume decreases and the static lessens. Is this what is known as Silver Mica disease?  The schematic does not document what size capacitors I have in the can. The transformer windings ohm out at 12 ohms. The transformer is a 32-1647. Any idea what size capacitors are in the can? If I ground out the antenna the noise is still there controlled with the volume. Am I correct assuming that the noise then is being generated inside the radio? On strong local stations it is still there but not as pronounced.
hello tludka,
These earlier sets did not have Mica problem
Well, I had the long wire antenna at about 15-foot height. I raised it to 20 feet and that cleaned up 95% of the noise problem.
Might be lighting static crashes you are hearing, they can be heard from long distance in the summer...
Simon
I find that interesting! So is the ant over something like a well pump or near the edge of roof. Glad it works. David
Have you cleaned your tuning cap?
New 37-116 Parts
I could be wrong but I believe that they have the decal sets in stock for 1937-38 model year Philcos, I didn't know that...Arran — 05:29 PM
New 37-116 Parts
I emailed Radio Daze last Thursday and got a reply back the next day. Their lead time is 4-7 weeks. I would image they a...dconant — 04:34 PM
New 37-116 Parts
Yes, I would recommend Mike also. Has good selection, and overall great guy. But he still needs the dial and the lett...morzh — 04:05 PM
New 37-116 Parts
Hello Doppleganger! Michael Katz is a great source for grille cloth. Good guy and Great service. Take care and BE HE...GarySP — 04:02 PM
New 37-116 Parts
Has your card (or what have you for payments) been charged? I emailed back and forth with someone this last fall about ...morzh — 02:30 PM
Hope the IF transformer is intact! Good luck! - GaryGarySP — 12:52 PM
New 37-116 Parts
Thanks for the relocation and sorry for the error. Yes - have called and emailed 3-4x and no response. IIRC when you...Doppleganger — 12:34 PM
New 37-116 Parts
Doppelganger No it is not the place, but it's OK, we will move it, possibly to "Philco Home Radios" (we oft...morzh — 10:33 AM
Hahaha, very true! In any event, the photo didn’t show any substantial rust on the top side of the chassis. It also clea...jrblasde — 10:29 AM
Donors always look good. Until they are out of their kidneys...morzh — 10:26 AM
