Philco Model Q-1717-126
I am new to the record player world and just inherited my grandfather's Philco. I know it was working at his house but in transit to mine something has happened and the albums will not play. I am not sure if or how to attach a video to here but can email one to someone. Everything looks like it is going to start working and then it just shuts itself off. Can someone please tell me if I am doing something wrong?
-Kyle
Welcome to the Phorum!
Icon_wave
I don’t work on many turn tables so can’t help much but hopefully someone will chime in. Q models are 1967 vintage so there could easily be lots of grime and congealed oil in the mechanism
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
There are currently 3740 online users. [Complete List]
» 2 Member(s) | 3738 Guest(s)
