Philco 201X incognito
Bob,
Tnx.
Don't know that the missing choke/added resistor is the issue. The current at that point is very little 1/2w would be fine. What I'm seeing is that in the present setup you have 2K+100K to act as the plate load for the 75 tube. It could be a little low. A typical load would be about 250K-1M depending on the plate voltage. With the choke in the circuit the load impedance is going to be higher than what you have now but the dc resistance will be low. Think of it like an output transformer's primary. It's much more efficient than using resistor.
Does the amp section have good gain? If so then it's time to have to look at the rf and IF stages to see if all is well.
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
There are currently 3752 online users. [Complete List]
» 1 Member(s) | 3751 Guest(s)
