Philco 95 Dial Cord Help
Good morning. I'm working on a 95 low boy. Does anyone have dial cord restringing info ? Thank you ,Bill
https://philcoradio.com/phorum/showthread.php?tid=3531
In case you ever work on something other than Philco radios, try this
[admin note: link was deleted because malwarebytes detected a trojan virus]
Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
Thank you Terry, good to hear from you !!!
Hi Bill,
Just as a side note there's a hand full of chassis that use that same setup. The 76,77,87,95, and 96 come to mind.
Good luck it's a bit of a pain...
Back to the 660L 770AM.
Thanks Terry. Is it possible to use regular dial cord on these ?
You can try it but it's got to be really tough. You have some of the original right? It's metal cable. Just to give you an idea what Phico used.
If your 95 is similar to the 514 I restored you might be able to use a flexible, light picture hanger wire. It's a little stiffer than the original but it worked fine.
Thank you Rod, I'll check that out . Best regards , Bill
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 2239 online users. [Complete List]
» 1 Member(s) | 2238 Guest(s)
