Fisher
Hi
A Fisher radio follow me around the other day, so I brought it home with me Icon_confused . I cannot find anything on this radio, Icon_sad I have tried several places and have put in requensts for any info and no one has answered. The model is R-30S, it has a Garrard RC-121 changer in and a 15 inch, a 8 inch and a 3 inch speaker, it sounds very good. I wonder if anyone here as any info on this?? Thanks to all
Joe
Sounds like R-30S is the chassis model?
http://www.grandcanyontuberadio.com/fish...20Amp-.htm
Sounds like it's more of a 1959 Contemporary II (C-810) with the R-30S chassis
http://audiokarma.org/forums/showthread....0&t=351050
Maybe?
Brian Mattson
Coon Rapids, MN
Beckett
Thanks for the reply
(R-30-S) is the chassis number I have tried everwhere I can think of to find info on this, but no luck. It has great sound and very sensitive. I sent a email to the guy that has the one for sale at (grandcanyontube radios to see if he has any info) but he never answered. I left a message at the other place you listed in your reply to see if he has anything. I have never worked with a radio that has less history than this one. But thanks for the reply. Maybe I can help you sometime.
Thanks
Joe
